MSI K9A2 Platinum
I know how to go to the Cell Menu but when I try to change the voltages of the RAM the option is greyed out. It will not allow me to change the voltage! Also as far as setting latencies which options do I change??? The sticker on the RAM says 5-5-5-15 I just want to make sure I change the right options.. There are many options that could be 5 or 15 I don't know what to do!!!! Also in AMD Overdrive.... What should the Memory Frequency be??? I would ssume somewhere way higher than 208.18MHz which is what it is right now... I need to get this stuff set! Please help and I will be happy to post benches along the way.
