SERIOUS question about hdd pluging in
HiCZoK
Hi all . I have explained everything on the plan :D
do not matter about dvd is not plugged that is only a simple plan
Plug the hard drive onto the end connector if it's the only one thing on the cable. Then you have to set that hard drive's jumper to master
