Alright I'm finally coming around to getting my hardware and in the past I've done some watercooling research, anyhow the parts I decided on buying as far as hardware has changed a little(for the better). I'm curious to know what parts are essential to get waterblocks for, what would be ideal to get waterblocks for, and what isn't too big a deal either way. Also if you don't think it needs a waterblock what do you suggest otherwise? I'll be OC'ing not sure to what extent yet.
Hardware specs:
Asus A8N32-SLI Deluxe
X2 4400+
7900 GTX
1 x 4 gb DDR400-500(haven't quite decided on this last part)
Anyhow, that's the basis of it, I've looked at some watercooling kits, since I may need to add additional waterblocks would it be smart to get a kit then add blocks or just do it all from "scratch" essentially? Thanks in advance.
Hardware specs:
X2 4400+
7900 GTX
