.......and most importantly run programs that are on one computer on another on the network....
That is where your problem is going to lie....
Without going into detail, a simple router (one you can buy at any retail store, BestBuy, Staples, even Wal-Mart) will allow you to start a small, simple network.
The computers you are trying to network, are they running Windows XP?
Remote desktop WILL allow you to use programs on another computer, but without it, 95% of programs will NOT work run over a network like that. It has to actually be installed on the local machine.... the DOS days are LONG gone!![]()
Thanks for answering my questions![]()
This statement confuses me a little bit. Remote desktop will allow you to run programs..... but without remote desktop programs won't run over a network 95% of the time? So that means, as long as remote desktop is being used you can share programs?
Or do you mean 95% of programs won't run over the network with the remote desktop?
