XxRoCkMaNxNEOxX
- Apr 11, 2004
im deciding to go to raid0 in the future but planning on just getting one 80 gig sata drive at the moment. I want a good harddrive that is fast but quiet. which brand would be better?
XxRoCkMaNxNEOxX said:im deciding to go to raid0 in the future but planning on just getting one 80 gig sata drive at the moment. I want a good harddrive that is fast but quiet. which brand would be better?
pirateface said:I go Western Digital.
Simply because they offer 3 years warranty on all their SATA products, and 5 years for their Raptors.
Wheras with Seagate their a bit picky.
They have listed 1 year for their 80GB SATA drive and 3 years on the other SATA drives.
You can take a look here:
http://www.seagate.com/support/service/psg.html
pirateface said:So go figure. Also I find WD SATA drives to be quieter than the Seagate SATA drives, but that's just me. I do own 2 Raptors and 1 WD 120SATA and the one 120Seagate 120GB I use at work seem to be a bit louder and more annoying than anything I've heard in a while.
Whatever, you can't go wrong with either one, just don't get Maxtors that's for sure.
Is that really fair though? I'm by no means a fan of WD noise, but you're comparing the first-generation, 10,000 RPM Raptor to a highly refined 7200.7, 7200 RPM by the way. And you should note that the second-generation Raptor, the WD740GD, is a great deal quieter than its predecessor.dave_graham said:interesting observation. For the roundup i did for Kyle last year, the Raptors were incredibly loud and annoying and the Seagate was whisper quiet.
Native command queuing will be nice...Also, stay tuned for the Seagate 7200.8 which has Native Command Queuing.
Do you have numbers that say the Seagate will perform on par with the higher performing drives? As of now, their performance is pretty mediocre, not that they are bad. Native Serial ATA support is pretty from an engineering standpoint, but I care much more about the end performance...don't you?It places the Seagate drives on par with the higher performing drives out there. Also remember, Seagate has the ONLY native SATA drives on the market; the other ones utilize ATA-to-SATA bridge chips.
xonik said:Is that really fair though? I'm by no means a fan of WD noise, but you're comparing the first-generation, 10,000 RPM Raptor to a highly refined 7200.7, 7200 RPM by the way.
xonik said:And you should note that the second-generation Raptor, the WD740GD, is a great deal quieter than its predecessor.Native command queuing will be nice
xonik said:...Do you have numbers that say the Seagate will perform on par with the higher performing drives? As of now, their performance is pretty mediocre, not that they are bad. Native Serial ATA support is pretty from an engineering standpoint, but I care much more about the end performance...don't you?
It's not fair because that evaluation is obsolete now. Western Digital has 80 GB Serial ATA 7200 RPM drives right now. That is what you should be comparing to.dave_graham said:yup, it's fair...not my fault that WD did a sloppy job of noise control on their "1st gen" (though one should really avoid using that as it's just a bridged EIDE drive) SATA drive.Scary thing is, Seagate was already on their second true generation of SATA drives by then...
yes, it is...at a price premium that's 3x's that of an 80gb Seagate.Seriously, the 74gb's are nice drives...
Okay, I can buy that...then why did you bother to say that the new Seagates were going to be "on par with the higher performing drives"? That's such a vague statement; you could say that much about the 7200.7 if you wanted to. It just doesn't sound that compelling. I don't know...maybe it's just me.Whitepapers are coming (seagate announced them yesterday or so) as well as reviews...stay tuned to Storagereview.com. As far as performance, do you REALLY think you'll notice a millisecond of difference? barely. For what it's worth, I run my 120gb Seagate as my "Games" drive and its on a non-pci bus bound SATA channel. It's a beautiful thing...games load fast, i can do what I want when i want to...
EDIT: the 3114 DOES support Native Command Queuing: see here. Granted, the source is Tom's but, it's a start.
xonik said:It's not fair because that evaluation is obsolete now. Western Digital has 80 GB Serial ATA 7200 RPM drives right now. That is what you should be comparing to.
xonik said:Okay, I can buy that...then why did you bother to say that the new Seagates were going to be "on par with the higher performing drives"? That's such a vague statement; you could say that much about the 7200.7 if you wanted to. It just doesn't sound that compelling. I don't know...maybe it's just me.
leukotriene said:I asked MS at lostcircuits about that in particular when it came out and he claimed Tom's is full of it. I believe him.![]()
That's not the point. The point is that when you compare 7200 RPM drives, you can throw that Raptor's noise comparison out the window, because it doesn't apply to the WD800JD 7200 RPM drive.dave_graham said:One could reasonably expect the WD SATA drive to perform on par with Maxtor's offering of the same.
No, all I'm saying is that you say that NCQ is going to put the 7200.8 in the running with the top 7200 RPM drives. What does that really say about its real-life performance though? Nothing. All of the 7200 RPM, 8 MB cache drives perform roughly the same in real life. All I'm asking is, knowing your philosophy on this, why bother singing the technological praises of the new Seagate when it's probably not going to make a bit of difference in real life?because, when it comes down to it, you're evaluating synthetic processes and metrics against "real world" application.
does this make sense or am I just being stupid?
xonik said:All of the 7200 RPM, 8 MB cache drives perform roughly the same in real life.
While the 400 GB capacity is no longer remarkable, the fact that it's accomplished with platters of an unprecedented 133 GB is quite remarkable.dave_graham said:btw, seagate has a 400gb drive coming out within the next quarter.
