themadmanrideson
- Mar 28, 2007
Building up a new system and my Seagate 80GB Barracuda 7200.9 SATA II (8MB Cache) has a jumper option to limit speed to 1.5Gb/s(when jumper is in place). Whenever I remove the jumper, trying to access the 3Gb/s range; the Disk Drive is either not recognized or hangs in the windows loading screen.
To be more specific: When trying to install windows the drive will hang in any formatting mode (quick or normal) and after installing windows using 1.5Gb/s config, removing the jumper causes the hang apon windows loading.
System:
-Seagate 80GB Barracuda 7200.9 SATA II w/ NCQ, 8MB Cache (x2) Currently in RAID 0 config to see if 3Gb/s would work.
-Gigabyte GA-M61PM-S2 Mainboard
My first guess would be the SATA Cables im using don't support 3Gb/s. Their the supplied cables from my Mainboard. (Yellow/SATA II)
Was also hoping someone could recommend a decent HDD speed testing software. One that would work for different Raid Array configs
Any Help or words of advice would be much appreciated!
theMadMan
PS If more system info or a better descrption of problem is needed, plz post.
System:
theMadMan
