SD31P - Where?
denaps
I am wondering if anyone knows where to buy the SD31P dual core intel SFF box from shuttle. i usually buy my stuff from newegg because i trust them, but they don't have it listed, and neither does ZZF.
Also, doesanyone know if a 7800 GTX (BFG most likely) will fit in that bad boy? my 6800 fits in my current SFF with no problems.
thanks
You can try CensusPC or MWave.
The 7800GTX will fit, as long as you take out the fan duct.
thanks a lot for the quick responses! i am assuming taking out the fan duct will not adversely affect the machine? i glad it will fit though as this is the combo i want.
