Scythe Ninja
Tzzird
I've just installed this "passive" heatsink and it works great on my p2.8. I can actually run it at 3.2 without raising the voltage, though I need to adjust the voltage from 1.525v to 1.6v.
The clips that came with the HS are meant for 120mm fans. I have a spare 85m lying around. Is there anyway to mount it using the original clips?
matt00926 said:
:wtf:
Buy a 120 mm fan
i second that, 120mm fans are cheap nowadays anyways. I thought only the Ninja Plus was available now and that includes a 120mm fan. If you didnt get the plus version, slap a Yate Loon on there and you're all set.
Yate-Loon D12-SL12
$2.99
Spend the friggin' money.
Best 120mm fan you can buy for the money. Panaflo, SilentX (LOL!), Scythe, etc. ain't got nothin' on it!
takeabao said:
Yate-Loon D12-SL12
$2.99
Could you possibly post a link to that... because I wouldn't mind buying one for 3 bucks.
Check the hot deals section.
