So Im retarded and bought a Ninja in hopes that it would work on the new AM2 platform, and well, it doesnt. Does anyone know if there is a mounting bracket you can buy seperately to make it work, so I dont have to go through the hassle of returning it? Thanks
EDIT: Ok, for anyone else that did the same thing, it will work using the socket 478 rention bars. Just bend the flanges for the screw holes and it seems to work perfectly. Not sure how much pressure is supposed to be put on the cpu, it seems kind of tight though. Try at your own risk...
