SCSI adapter question
the snake
in the process of build a new system, want to use my 2 fujitsu 15K ultra320 drives in it, but i want a faster card than the current 160 PCI card i run.
my mobo is a abit IP35 pro with an extra PCI-E x 16 slot, but it says it is only 4x bandwidth, so if i get a 8x bandwidth card, would it work or should i only look for a 4 x bandwidth card ?
or would a 1x slot provide full bandwidth for ultra320, isn't 1x PCI-E limited to only 250MBs ?
as you can tell i am slightly confused here LOL
was looking at this one here from newegg....
Adaptec 29320LPE PCI Express
you should be fine, 1x is 250megs for the serial interface, bidirectionally. where the theoretical max for pci is 127mb/sec parallell.
i'm in the process of implementing ultra 320 tapes on pci-e controllers at work, so i will have some real honest to goodness real world thruput numbers later this week.
