Screen Artifacts right from powerup
edliu512
I just built a new PC with BFG 8800GTS 512(G92) OC, the computer ran ok for a few days, until today.
I have no over clocking on any of the parts. Last night I left the computer on over night and in the morning it was frozen with a blank screen. When I tried to restart the computer I a little bit of artifacting right through powerup, but windows freezes at the log on screen with visible artifacts where rectangles of color became visibly different than normal. At this point, I tried and succeeded booting the computer into windows with video driver disabled by using the enable vga mode boot option. I saw no artifacts with the generic vga driver, and programs all seemed to ran fine. So I reinstalled the graphics card drivers and reseated the card in the PCI-E slot. After the reboot the artifacting was gone, and everything was normal again, and games and other software all ran fine. But after a bit of gaming, the PC crashed and I saw artifacts again, right from powering up. This time the screen is filled with vertical and horizontal rows of black dots all through out the screen, and some of the command prompt letters are pink colored instead of the normal white colors. I tried to boot with window's generic VGA driver but the computer crashes and self restarts at booting into windows, however I can boot into safe mode ok. I tried to let the video card cool down and reseating the card in the pci-e slot but I still see the same problem.
I am suspecting the video card is broken, anyone know if anything else could be causing the symptom I am seeing?
My guess would be Video card too. Sounds like its overheating. Leave the PC off for a while so it will cool down then try it again. If it boots up OK but craps out again after things heat up have a look inside and see if you can sort out any heat issues. If it won't boot up even when cool the video card may already be damaged by overheating the first time you left it on all night. It could be something else but my first thought is video card problem. I had an artifact problem years ago and it ended up being my video card. It started out only showing up on high screen resolutions but got worse and eventually the PC wouldn't even post.
