older cheap lcd - worked fine with my old x800xl and then on my 8800
sold it to a friend with the x800 and she's used it without fail
now i just upgraded her setup - amd x2 and a his 4650
all through setup the monitor worked just fine - loaded vista, display drivers from microsoft were ok
i loaded the latest cat drivers and restarted - now the monitor goes out of sync when windows loads
connected through a dvi cable, i dont know which kind [dvi i or d or whatever...]
no matter what resolution or refresh i try - the monitor will not sync with the video card
i tried both my monitors, my dlp hdtv and an older crt - all worked just wonderfully... but this older sceptre just isnt digging it
any tips?
im going after work to try both vga and another dvi cable to see what's what...
any tips?
