I'd like to think that the title pretty much explains it - but I guess it's a pretty elaborate operation that I'm looking for here, so I'll go into detail a little more. I do, however, apologize in advance for this hellishly long post.
I'm working as part of the IT Dept. at the university I attend, and our 'Scheduling & Activities' office for the entire campus is interested in transitioning our 'paperful' (if you will) office into one that would be almost paperless.
The problem exists in the filing methodology of the current secretary who runs the office. Everything (and I mean everything) is printed out and kept in one of the millions of filefolders she has in the many 8-drawer vertical filing cabinets that hide the actual walls of the office.
The problem with this is that with the current system, it often takes an hour at the least, and sometimes as long as a day, to find one single piece of paper. Worse yet, the office's secretary is the only person who actually knows where every one of those pieces of paper is filed at.
Bottom line: She's retiring next year. We have a nightmare of nuclear-holocaust proportions on our hands.
What we could really use is a system that does the following:
Budget isn't really a factor at the moment, so fire at will. Thanks in advance!
- Can utilize a sheet-fed TWAIN compliant scanner to scan forms...
- Then save each form to an Adobe Acrobat 6.0 PDF (or similar format), OCR'ing as necessary but essentially keeping the original formatting of the page...
- Finally allow us to save each PDF into a centralized database that would be kept on a redundant fileserver.
- This database must allow us to search for the filename of each PDF, as well as search the entire contents of each PDF, and must be able to be modified by multiple users at once over a LAN.
