SATA with IDE issue
2kool
Hi People,
I have have just installed a WD raptor sata drive. I disconnected my ide drive while I reinstalled windows and sp2, I used the floppy method to install the promise driver. It installed no issue sweet.
I now plug in my Ide drive that only contains backup info etc, I now boot the system and get an error that says I have no OS installed and need to insert disk etc..
System specs and setup:
ASUS a8v delux - 108 bios
WD 74 GB sata raptor 10k
WD 80 GB IDE
I have the sata on the promise array, bios set to enable/ sata IDE.
The IDE drive is on the primary IDE channel and jumper is cable select.
Now I assume this is me being a Dufuss but if you can help that would be nice..
Evo
