I have a (crappy, but it's all I can afford right now) ECS P4M800PRO-M motherboard and a Pentium D 915 (default FSB 200). I had some prior issues which seemed to be caused by the RAM but I think it was because the wrong CAS latency was chosen.
The system seems stable when the FSB is in the 220s or so - it's been running Prime95 for several hours with the FSB at 220 without any problem, albeit a little hot (in the 60s celsius but I have a small case with low airflow) Heat issues aside, when I get near the 230s, I have problems with my SATA drive. The drive's name is corrupted and of course it doesn't boot (the SATA drive is my boot drive). Is there any way to fix this? According to ECS the board is supposed to support 1066MHz FSB chips, meaning I'm not even near the 266 FSB it's supposed to support. I've also heard that the chipset (VIA P4M800PRO) was designed for 800MHz FSB chips at max and that the chipset is practically running overclocked otherwise - might that be the problem? I know that it's sorta silly to OC on a board like this but I just wanted to see what I can do with what I have. Thanks!
