AdamNesvick
- Jun 18, 2006
Ok, I am tryin to get away from PATA completely, are there any out there at a good price?
I know plextor makes one, but I'm cheap![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
tazzmissionx said:AFAIK, Plextor is the only one that makes SATA optical drives, and it seems that people have nothing but problems with them
nekrosoft13 said:wrong
Samsung has them too
when it comes to verbatim be careful, don't buy media made in India, those are made by Moser Bauer, horrible quality.
when it comes to Verbatim made in Taiwan, those are not made by Mitsubishi Chemicals either, they are out sourced to either CMC or Prodisc, you can find out wich one you by Serial number on inner ring. CMC made Verbatim media usually burns better.
For best results always get Taiyo Yuden media, you can sometimes find them in Best Buy, most Fuji made in Japan are Taiyo, Panasonic made in Japan is Taiyo, and some Sony made in Japan are Taiyo.
nekrosoft13 said:not a single verbatim made in Taiwan is made by Mitsubishi Chemicals. ZERO, NADA.
they use the same technic(or very close it), they still have the same Media ID.
but if you look at the inner circle, if the serial number starts with PAPA, then the disc are made by CMC.
If the serial number looks something like this 123456+789012 (notice the +) then its made by Prodisc.
you can only find real verbatims in very small numbers in Europe, and Asia
Limahl said:The ones I have here don't match either of those, DVD or CD.
I dont see PAPA or any + symbol mixed in with the letters/numbers on the inner circle.
Oh well, I'm not gonna lost any sleep over it in any case. These blanks work fine in this drive and thats all that really matters. I knew going into this anyway that to burn a DVD at 16X and have it be a quality burn that the media would need to be more than the typical blanks at WalMart. Plextor recommended these, and they work mint, wherever they were made.
Odd that every program I have that will tell me manufacturer says Mitsubishi, are they all just reading it wrong or is someone somewhere lying about it?![]()
nekrosoft13 said:doesn't matter what they say, its still not real media
it all started when people realised that CMC made media and some Verbatim have the same serials, and after long time of test, and info gathering, its true, Verbatim oursources their media to CMC and prodisc
here are few threads
http://club.cdfreaks.com/showthread.php?t=187234&highlight=verbatim+cmc
http://club.cdfreaks.com/showthread.php?t=188011&highlight=verbatim+cmc
http://club.cdfreaks.com/showthread.php?t=128909
just read those threads, and you have either one of those serials on the clear inner hub, you have to look very close, hub is clear so are the letters, it only shows under the right light angle.
if those don't match, then you might have made in India Moser, which are much worse.
i respect this forum for hardware (amd, intel, boards and video cards), but when it comes dvd-burners and media nothing beats CDFreaks
