SATA drive cable
Excavator
My new 74GB Raptors came with SATA cables that also have the power connection. Can that power connection draw too much from the motherboard? Would it be better to use a normal SATA cable and get power directly from the power supply?
Those cables don't get power from the motherboard, they simply connect to the power connector for a more solid connection. If you use that, you must use a 4-pin molex as well.
