Sata Cable Length (?)
liquidfluidity
Does length matter? Is there enough resistance in the cables we use, to create an issue with longer cables? I'm getting ready to re-do some cable routing and need some longer cables for my drives. I'm needing 24" but I am finding a better selection in 36" - at least there seems to be more to match my color scheme and that have the correct angle ends. What are the best cables or are they all basically the same except for cosmetics?
