I recently put together a new system using an Asus P5E and a new Seagate 7200.11 750GB hard drive. The motherboard is SATA 3.0 Gb/s specification and the drive is too. I noticed the jumper on the back of the drive is set to limit to 1.5 Gb/s. This may be a stupid question, but I assume I can remove the jumper so the drive will operate a 3.0 spec, right? It seems odd that the drive would be set to 1.5 "out of the box" so to speak. The seagate manual says something about a "host adapter that supports autonegotiation". What is that? Are there any other settings I need to worry about? Any bios adjustments?
Thanks
Thanks
