Mar 9, 2007 #1 M meds Weaksauce Joined Aug 12, 2006 Messages 123 I need help programming a bell expressvu remote to use with this TV. I have a 3100 expressvu dish and I've tried the sanyo remote codes, I've also tried scanning mode to search for a remote code.. but to no avail. Any help would be appreciated!
Mar 10, 2007 #2 M MrPatate Gawd Joined Jan 4, 2007 Messages 1,021 i think you're in the wrong place, you should go the a remote forum or something like it... Does your remote have a learning capability? if so,just make it learn all the buttons from the sanyo tv..
Mar 19, 2007 #3 M meds Weaksauce Joined Aug 12, 2006 Messages 123 I called tech support.. but they can't get it to go. Any remote forums you would suggest?
