hutchingsp
- Dec 24, 2006
Wondered where you stand on SAN/NAS on whether you prefer hardware over software.
Let's say you need a 5TB NAS/SAN.
You can go out and you can buy any number of hardware units that range from a $1000 Synology/ReadyNAS up to $50k worth of 3PAR and so on.
Or you can take the view that a SAN/NAS runs software, so why not run that software on a commodity servers?
Servers are cheap, servers are redundant, and generally you'll be able to buy a server with redundancy equivalent to what a cheap SAN/NAS will provide, and run high end SAN/NAS software on it for way less than you'd spend on a high end hardware SAN, IYSWIM.
You can also do things like SSD caching on the RAID controllers quite cheaply vs. the sort of cost (hardware and software) that the big players will charge for that sort of thing, though it's not as granular of course.
I'm not talking about whiteboxing and running "Some Linux + NFS" - I'm on about storage software with end to end enterprise grade support.
You can probably tell which side of the fence I sit on here - I can't help but think that storage as software is on the rise and it makes more sense to spend $10k on software that can be replaced if needs change vs. $100k on hardware that does the same thing but you've got it for 5 years come what may...
It's a given that it's not for everyone there will always be situations where hardware is best either for performance or those last few 9's of availability.
Which side do you sit on?
