- Feb 8, 2005
My school recently switched from a 42U rack full of Dell servers to a single 7U blade chassis, a 3U SAN, and a 1U switch. It's the first I've heard of businesses using "virtualization" to simplify their network. Apparently, they're running VMWare and 40-someodd instances of Server 2K3. The specs they told me were incredible...
Now on to my questions.
1) Theoretically, the throughput of a SAN should be significantly higher than that of a locally attached disk, right? How much higher?
2) Is there a latency hit associated with using a SAN as your only hard disk?
3) Is it likely that my school WAS using a SAN as their only disk? There were two little laptop-drive-sized hot-swap bays in each blade. Would they be using these instead? Why or why not?
4) Is VMWare an OS now, or were they running it on top of linux/server2k3/etc?
5) Does the chassis have some sort of OS associated with it? Or are they using one of the cores on one of the blades to run VMWare?
6) Any nifty links to read up on?
