Samsung Color Laser Printer Problems
Format _C:
My friend has a Samsung CLP-315W color laser printer and he just replaced all of the toner and the imaging unit/Drum/Fuser. but the printer is still having an image retention problem. What I mean is you print a document with more then one page and the second page still has an image of the first page across it. (The second page is on the paper with an off center image of the first page) If he waits 30-60 Seconds before printing the next page it will come out fine. He cleaned the rollers and the problem still exists.
Does anyone have a solution that does not involve buying a new printer?
Thanks
err... not to come across as rude but why spend more than the thing costs to try and fix it?
A Fuser alone is like 80% of the cost of a new one. Fuser+Drum is more than it's worth.
