Hey all,
I just got my 204B in the mail. I hooked it up to a PC here at work using the Dsub cable. The backlight didn't work. I could faintly see things on the screen, but the backlight was completely off. So I removed it from it's stand with the intention of opening it up to see if a cable was knocked loose or something. There are no screws, so no way in. I then hooked it up to a different PC with a different Dsub cable. It worked like a charm. So I take it home and hook it up (via DVI). It worked just fine. Then today I wake up and my wife tells me that the LCD isn't working. I check it out, and sure enough, the backlight is off. I've tried banging the thing to see if its intermittent, but that doesn't do anything. Anybody have any experience with this? Thanks
