Samsung 173P help.
bruce02
I just started using DVI with it today, and the colors don't seem as vibrant as they were before. I'm using an X800 XT video card, and MagicTune stopped working after I installed it (I tried reinstalling, but it won't work). Any ideas?
Strange,I know mine quit working after installing new drivers so I had to uninstall and then reinstall MagicTune,but if that doesn't work I don't know what the heck is wrong.
When you go to DVI things change a bit. DVI takes over control of many functions over which you use to have manual control.
You should still be able to get to your individual R G B settings in the monitor controls, a lot of adjustment can be make there.
I use an ATI 9800 PRO and I used to use “Natural Color” for all my settings adjustments. It loaded with windows and kept my profile as I had set it.
I recently downloaded and am using the new Cat drivers with the new Control Center. The Control Center took over for Natural Color. You can create one or several profiles in the ATI Control Center and use them at will, but your desktop profile will load on reboot.
The Control Center settings are still a bit buggy and I’m sure will be improved over time, but they DO work and work pretty well.
Give it a shot :D
Luck
