Immolation1991
- Feb 23, 2016
So I bought a RX 470 4 GB Armor recently, but having trouble running it over its displayports.
Whenever I start a game, after a couple of minutes or so the screen starts to show artefacts, flicker and then goes black. PC is running as usual, monitor is getting signal, but the gpu just shows a black image, after reboot everything works fine again, also no problems in idle/browsing use until I load up a game again.
The thing is DVI and HDMI seem to work perfectly fine. Played 2 hours without any problems. So it has to be related to the DPs
here is what I did so far without success:
-tried all 3 DP ports with 2 monitors and 2 different DP-cables which always worked fine
-tried 4 different drivers, among these the oldest supporting the RX470 and the latest, always used DDU in safe mode etc,
-uninstalled/deactivated AMD HDMI sound driver, because the monitors implemented speakers make ugly static sounds as soon as the problem occures.
-RMA, got a different card (hope so at least), same problem
-temps, fans and clocks fine
-power cycling
could it be the DP 1.4 not being supported or are my cables not good enough for it?
unfortunately I need DP for my main monitor.
my rig is fairly old otherwise: 2500k, Asrock Fatality p67, Win 7 64bit
Any thoughts?
-power cycling
Any thoughts?
