Running a motherboard without a case?
xBanzai89
I have a motherboard I want to check to make sure it still works before I sell it. I don't want to take my current computer apart to put it together to check. What do I need to put below the motherboard so it there isn't any damage?
I have run many a system just sitting on a cardboard box...should work fine for you too..:)
I also had a system up and running for a year or so on a 12" X 12" piece of plywood....
Lol thanks for the quick reply. I'll do the cardboard box idea. I was just afraid of any electrical issues that may come about.
I have found setting the motherboard on the box it comes in works well ;). Surprisingly, the box is the perfect size to set it on :p.
^^ what they said. Mouse pads are also a great thing to set electronics on.. well the old school ones.. not "newer" metal ones. Glass also works.
I use my freakin' huge mouse pad.. it's big, anti-static and umm.. on my desk at all times.
Well it works. I'm posting this message from the setup right now. Thanks for the help again. I only had trouble figuring out how to make it power on. I saw the the power section trip it with a screw driver, worked like a charm. Now just to post it up on the FS forum.
i test ALL my motherboards on the box they come in BEFORE i go through the HELL is to put it in a case, and then find out it does not work
I was thinking about running my 8400 and 750i FTW motherboard, gtx 260, without a case. Is there any potential problems when doing this? I will put a small desk fan blowing over it when I'm using it.
If this is not smart, what are the potential problems, and what will I damage?
My motherboard has a small fan on it, my cpu has a fan on it, my gtx 260 has its own fan...
Thanks for reviving this thread after 14 months for no reason instead of starting a new one.
And no, there are no potential problems as long as you place the motherboard on a non-conductive surface like the rest of this thread talks about.
ditto, actually just today got my current system in a real case, been in a box on the floor for a few weeks now, i took an extra step and made four little "standoffs" from 2x2" pieces of folded over cardboard from the box just to allow heat to escape from under the board and to allow the pci cards to seat in fully because of how the slot cover extends beyond the plane of the motherboard...worked 100% fine although rather warm for a little bit
and then the search nazi's would jump on him for creating a new thread instead of using the search button!!! LOL
What about air flow, is that a worry when the motherboard isn't in the case? Do I need to use an external fan?
motherboard doesn't get hot. inside it gets hot. cpu and ram and vga. also your hdd's but that varies how many you have.
yes you can run a computer outside your case. but you have to use the stands which your motherboard sits on. bolts or whatever and there you go. make sure something empty and non-anti static is sitting under it like a box or something i suppose. just for testing purposes ONLY!
The Antec Skeleton and many of the "Tech Stations" are designed around open airflow... they don't have enclosed sides and many have fans to blow air across the components. Downside is they seem to cost as much or more than a regular case.
The only problem I could foresee would be down the lines of curious pet/ child damage. (Just make sure you dust it now and then)
+1 I've assembled a system before to find out something is screwed up with the mobo. Damn wire management!
Would it have mattered either way? Why do you care?
I care because when people revive threads this old to ask a new question, inevitably a whole glut of people will come into the thread and reply to the original poster (who probably hasn't visited the forum in ages and has either dealt with the issue already or doesn't care any more), without bothering to read the new question. So you get a few people giving constructive advice and a bunch of others replying to the OP for no reason. That's one of the reasons why starting a new thread is better than reviving a dead one.
