three_sixteen
- Feb 15, 2002
It's magic! Just got my token today. Never had the chance to play around with this stuff before. What kind of battery is in it that can last 3 years though? ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
BillLeeLee said:Ooo SecurID.
Do you guys use the appliance, or is it just a box that you guys set up to manage all the tokens?
Do you have to brand spanking new SID800 tokens (the ones with the USB port)? Or the more water resistent SID700 (no USB port)? Or the even older keyfob (black rectangular)? Tokens are also supposed to last 5 years until they expire (I'm sure you've seen the expiration date on the token).
Plus I hope you guys do actual two-factor authentication, and not the TOKENCODE_ONLY mode. That would be rather...pointless.![]()
BillLeeLee said:Well, if you know where the comp is located, that would be the easiest way to tell (the appliance is a 1U rack-mount machine with the words RSA SecurID on the front and a twist knob.
Otherwise, if you know the machine's hostname...you can try accessing its web interface through port 8098. That brings up the authentication page to log into the appliance web administration portal. This is only for appliances. Regular boxes don't have that portal.
Of course, it really doesn't matter, the appliance is just a set top box with all the necessary stuff built in. I just like them since I think they look so cool.![]()
BillLeeLee said:Wow, an SD600 (the old keyfob). They don't even make those in the US anymore (all of those come from Ireland now). Those are built pretty rugged too, there are stories about them surviving major disasters. I think the one that people like to tell now are that a bunch of keyfobs were submerged for about a month in the aftermath of Hurricane Katrina, and when they were recovered, they were working just fine.
http://www.rsasecurity.com/node.asp?id=1311
I use the SID800 from work. There's an even newer model out but it's in the form of a pinpad. The SID800 is where it is at though (can be used for sign-on manager, remembering settings and such, as well as standard authentication. It is the jack of all trades token).
BillLeeLee said:The USB port is used for things like RSA Sign On Manager, where you can insert it into a workstation's USB port to provide log on credentials (the information is kept in an encrypted certificate on the embedded flash memory inside the token).
It can also be used for things like remembering log in information for other sites or software, as well as for other authentication services (through X.509 certificates).
I only use it for the token codes though.![]()
