FurBurglar
- Jan 14, 2005
I was wondering if anyone has figured out any kind of solution to replace the crappy flat cable that runs from the X-Fi internal card to the I/O panel. I thought it was just an IDE cable, but when i got to looking there are different holes in the plugs blocked off that renders them incompatible. Has anyone some up with a good solution? Thanks.
