ultimoamore
- Dec 30, 2011
Using the same Belkin USB wifi adapter, one PC works fine, while the other has "rollercoaster" bandwidth. Basically works ok for about 30 secs, then stops for 30 secs (0 bytes/sec) then it's ok again.
Here's a ping -t result (see the "general failure"...):
Reply from 10.0.0.1: bytes=32 time=71ms TTL=64
Reply from 10.0.0.1: bytes=32 time=230ms TTL=64
Reply from 10.0.0.1: bytes=32 time=76ms TTL=64
Reply from 10.0.0.1: bytes=32 time=186ms TTL=64
Reply from 10.0.0.1: bytes=32 time=217ms TTL=64
General failure.
General failure.
General failure.
General failure.
Request timed out.
Request timed out.
Request timed out.
Reply from 10.0.0.1: bytes=32 time=5ms TTL=64
Reply from 10.0.0.1: bytes=32 time=9ms TTL=64
Reply from 10.0.0.1: bytes=32 time=2ms TTL=64
Reply from 10.0.0.1: bytes=32 time=3ms TTL=64
Reply from 10.0.0.1: bytes=32 time=15ms TTL=64
Reply from 10.0.0.1: bytes=32 time=19ms TTL=64
Reply from 10.0.0.1: bytes=32 time=168ms TTL=64
What should I look at?
General failure.
General failure.
General failure.
General failure.
Request timed out.
Request timed out.
Request timed out.
![29bkh90.png](http://i41.tinypic.com/29bkh90.png)
