RocketRaid's "Variable Sector Size" feature?
devn9ll
Does RocketRaid's "Variable Sector Size" feature really allow greater than 2TB volumes in Windows XP (32 bit)?
in order to have array over 2tb you need to use gpt for partitions, windows xp 32bit doesn't support gpt partitions.
So no one has experience with this advertised feature on RocketRaid cards?
The PDF doesn't even make it exactly clear what the VSS does. How annoying.
