ajdmidjadzmd
- Apr 29, 2008
Does anyone know where I could find a replacement top panel for the Rocketfish? I purchased one that I was told would fit from Cooler Guys (model t-71--fits the PC-A71), but much to my dismay it doesn't fit. Just a bit too wide. Other than the width, it appears to be a perfect fit. It seems that tis is where the difference lies in the Rocketfish and the original Lian LI. That little bit of extra width would be ideal for cable management as well as the motherboard placements. Anyway, I would appreciate any info on a top panel with vents . Thanks
