D
Deleted member 104402
Guest
a
It just depends on the time of day, your location and other factors. I have Roadrunner Turbo and my download speeds are normally above 20 Mbps.
Try running straight from your computer to the modem, other wise give Time Warner a call. They have the ability to look at the modems advanced configuration, and see if noise or something else is effecting your quality of broadband connection.
dont ever do this. you might as well just download and install a virus yourself.
Or do you never conenct to any public WI-FI hotspot also due to security concerns, ever?
