R0achTheWarHero
- Jun 9, 2007
Soooo, you are going to buy an LCD but you're like omg Roach I am a noob, what LCD should I buy? Well I'm glad you asked. First we will cover:
Size
- 15inch - do they even make these anymore?
- 17inch 4:3 - waste of time
- 17inch 16:10 - is this a joke?
- 19inch 4:3 - pretty dumb idea considering how cheap bigger ones are
- 19inch 16:10 - wow you got ripped off
- 20inch 4:3 - the first panel to consider, if you don't want to spend a lot and like 4:3 aspect ratio this is your option, the vertical viewing height is just enough to not be irritating
- 20inch 16:10 - SEEMS like a good idea at first, later on you will notice the vertical height is too short and wish you got something else
- 22inch 16:10 - If you're a cheap ass and want the biggest screen per dollar spent ratio then this is your choice, also the smallest 16:10 screen that has a large enough vertical height to not drive you insane
- 24inch 16:10 - you will probably be considered a pretty kool dood if you got one of these, probably score lots of chicks or mantrains or whatever it is you do
- 26-27inch 16:10 - would recommend this over the 24 if you can afford it, same rez but the dot pitch difference isn't a problem at all
-30inch 16:10 - not recommended, price is high, backlight issues are bad, resolution is very high and requires dual link cable and video card, poor for gaming usually even if running SLI with 2 highend graphics cards, 26 or 27inch probably better choice even if you have the money for 30' unless you have to get an IPS screen because they are more abundant in 30inches than 26-27.
Panel Type, Ghosting Effects, Color/Contrast and Appearance:
TN - 6bit + dithering : TN panels have come a long way and panels such as the Samsung 226bw S panel actually display similar color to many PVA/MVA/IPS panels, most don't though. The appearance of the monitor can be described as a bunch of fine grains of sand packed together or grainy in general. The type of ghosting seen on this panel type can best be described as a blur of solid mass with no transparency. If you're an artist or photoshopper on a budget, a calibrated 22inch S panel will work good. Samsung is the only TN panel manufacturer I know of that makes TN panels passable for photo work so don't bother attempting it with a chi mei or other brand unless they get their act together.
IPS 8bit - This panel type is the best for photoshop or artists, the sole reason is viewing angle. Many claim IPS panels have the best color but thats not really true, PVA panels and some MVA are doing just as good in the color department while having higher contrast at the same time, the only problem is VA panel technology has an inherent "black crush" effect on dark areas that hide detail. Being an artist myself, I can tell you there is really no workaround for dealing with black crush effect in drawing or editing workflow. If anything, trying to compensate for this effect would probably give you some bad habits that would make you a worse artist over time or just basically drive you crazy and end up selling the monitor. Panel appearance and ghosting of IPS appears similar to TN panels except with better color representation and similar to TV viewing angles.
MVA/PVA 8bit - As mentioned above, usually the best contrast ratio of panels, similar color accuracy of IPS panels. In terms of panel appearance and ghosting, MVA/PVA are completely different than IPS and TN though. Some will disagree but I'm going to go out on a limb and tell you that MVA/PVA does not look as natural as IPS and TN (based on experience with the LG246 MVA panel and Dell 2405 PVA panel). Whereas most TN and IPS panels appear to look like the image was created with fine grains of sand or "grainy", the MVA/PVA image appears slightly "muddy" kind of like it was created with high resolution crayons is the best way to describe it. The ghosting effect of these panels is completely different than TN and IPS. Instead of leaving behind a solid blurred mass in movement, these panels will usually leave more of a translucent ghost, there is still a blur of the solid mass but the majority of the ghost apperance length will usually be the translucent image.
*Will finish the rest later
Size
