rivet sizes?
bubsie
Hi,
I know this question has been asked before but what size rivets should I use to replace the ones on a computer case? Thanks
Depends on the case. However, most cases use 1/8" rivets. Or rivets that fit 1/8 inch holes... one or the other.
Yes, should be 1/8". And make sure you get a rivet tool if you don't have one already.
