Rig for video editing and rendering?
Great Tiger
Video Editing using Sony Movie Studio 12
$1000-$1200 I can shop at NCIX.com
Vancouver BC Canada
Mobo, CPU, RAM, CPU cooler
I'll be reusing my OCZ 1000W PS, SATA DVD Drive, PowerColor 6990, Creative X-fi pci-e sound card with front bezel) Bitfenix Colossus XL Case, 2 128GB Crucial M4 in raid-0 and two 1TB storage drives.
6) Will you be overclocking?
Nope.
I currently use a 47" LG LW5700 passive 3D TV hooked to the 6990 via HDMI
Within a months time.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Please see below these questions.
Legit windows7 64bit bit license.
Gentleman, how are you? It's been a while and these days I find myself needing a little bit more horsepower. I've been getting into video editing and the rendering times i'm sure can improved.
Besides the above mentioned, I currently have a 965BE cooled with an H50, 16GB 1333, a AMD 6990, and two Crucial M4's in raid-0. This has suited my needs up until now. From what I gather for rendering and encoding Intel is the way to go. Gaming isn't a big priority these days, satisfying clients is.
I have $1000 I can work with but stretch a little if need be. Meaning if we're a little over that it's no big deal. I can purchase everything right from the store at NCIX.
Basically, I only need the Mobo, CPU, and RAM. I can reuse the cooler if need be, I need reliability so overclocking on business oriented equipment is not an option at this time unless of course your are confident in the parts you've chosen.
This is the [H], don't think I don't know how to take [H]ard advice. If you feel a particular combo overclocked will yield me maximum results within my budget but still provide 100% stabability, by all means please do so. I would be happy to report my results based upon your reccomendation.
It seems strange to be the one asking for advice this time. 10% bonus chance in an area of your life for helping me out. Cheers!
I personally would go with an Intel 6 core processor, 16GB ram and an Asus motherboard if it was for me.
some people aren't fond of Asus anymore but I have not had any issues with them in the 19 years I have used Asus boards.
there are 2 six cores I see, 5920k and 4930k.
Both have similar PassMark scores, 13K, the 4930 is $200 more though. not sure what the differences are.
http://www.amazon.com/Intel-i7-5820...8&qid=1411766564&sr=8-2&keywords=intel+6+core
The difference is that the 5820k is the new Haswell-E architecture where the 4930k is the slightly older Ivy Bridge-E arch. The 5820k build which uses the X99 chipset is going to be more expensive as everything is new and the DD4 it requires is still at a high price premium.
In your budget range you could get away with this:
I7-5820K: http://www.ncix.com/detail/intel-core-i7-5820k-3-60ghz-six-c4-100097-1342.htm
G.SKILL Ripjaws 4 16GB 4X4GB DDR4: http://www.ncix.com/detail/g-skill-ripjaws-4-16gb-4x4gb-a7-101221.htm
ASUS X99 Deluxe http://www.ncix.com/detail/asus-x99-deluxe-atx-lga2011-3-x99-e9-101202.htm
Total: 1171.92 CAD
Definitely a solid build of the latest and greatest. If you check out the front page, it is a pretty great overclocker and stable at decent rates which should help for your video editing.
Thanks iLLuSioN that seems like it'll work although i'm not sure a sound card is going to fit that mobo with the 6990 in it. Will the X99-A work just as well? It's got an X1 slot lower then the videocard slot so I can put my sound card in it. lol
Thanks for all that contributed.
is there a reason you need a sound card, most mobo's today have plenty of sound capabilities built in, i personally have an x79 deluxe which is a bit older board but i have no issues with on board sound
I am using onboard sound with my Alesis monitors and it sounds excellent,
Yeah you could save some money by going with the X99-A, if putting your card it in the #1 x16 slot blocks your x1 then you can just simply move it to your #2 x16 without any issues.
