Hi,
I just had an idea, instead of a power button, i would replace it with a RFID card/key chain reader... But the only things i found were either for commercial use($$$$) or this http://www.canakit.net/Default.asp?...//www.canakit.net/Contents/Items/RFID-101.asp ).
Key Chain RFID http://www.canakit.net/Default.asp?...ww.canakit.net/Contents/Items/RFID-KEYFOB.asp
Is it possible to do it(nothing is impossible i know... is it "easily" makable)?
Do you know where I could get a reader for only 1 card (i suppose it will for at least five, but i guess it will be cheaper than 42 )?
Will i need to "program" it or i can simply set it like this?
Everything is to scale of course Admit you are jealous of my drawing skills.....
thanks!
thanks!
