I want to rebuild my moms PC for her sometime soon so I have found all the hardware minus a case. I always liked the way her old gateway looked and I think I wanna reuse it. The only concern I have is heat issues caused by the small size of the case. Below is the support page for the model she currently has and a picture of the inside of the case.
Support page
http://support.gateway.com/s/PC/DX400/1014104R/1014104Rnv.shtml
Inside
So I'm going to put an 80mm or 92mm in the back and I think I'm going to Jerry rig a 120mm in the front where the hard drive bay is. I'm going to get rid of that cage and put the hard drive under the CD drive. Do you think heat will be an issue with the new hardware I want to put in?
Here's all the hardware I'm buying. I may also reuse my old 8800gts if the integrated graphics don't cut it (I doubt that though because she will be doing mainly office work).
Heres a Newegg wishlist with all the hardware. Thanks in advance for all the help.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=21567205
Support page
Inside
