My first ever mod/worklog. I have zero experience and I m sponsored by my bank account, Google search and friends/family.
My Rig has served me very very well and it still has plenty of life remaining.
Specs:
Intel Q9950
Asus P5Q Deluxe
Corsiar DDR2 1066 (4gb)
Segate 1tb drive
GTX 460 768
(old) 500watt antec psu
Antec Sonata III case
But it needs a makeover in the worst way....
Yeah that case has been though a whole lot.... (college)
The guts are simply an abomination. The dynamat was a mod I did back in 08 due to my hearing condition. My case is pretty silent, even with the cpu heat sink fan pointed in the wrong direction.
I need to do something with that fan cover (or lack of). I removed it a few years ago on a whim. A very bad whim as it turns out. I dust once every month now to keep the dust under control and I m failing with dignified.
Its a mess.
In fact almost everything in my computer has some serious miles on it. For fun I did the math and averaged out the age of all the pieces of my rig which came out to roughly 3.8 years. This means that if I want my rig to last another two years, it wouldn't hurt to give the old girl a fresh coat of paint (literally). And before someone posts this no I am not buying a new case, nor should I. I love what I have as its simple, silent and compact. Plus were is the fun in just buying something new when you can build
For this restoration/mod I have done and plan on doing a number of things. (portions in bold are what I have done already)
1 Clean it. Clean off all of my components while I transfer them to a temp case.
My pc has been transplanted. I successfully removed the dust and grime from the components. Have an issue with my gfx card..
Borrowed from a good friend. Too large and loud for my liking, but it is doing the job.
I d like to get that dust off, Idk how though.
2 Get rid of the glue/scratches and repaint steel portions of my case. Also remove the last of the old metal fan cover.
In the middle of this right now. Turning into a bit of disaster.
I will be borrowing a dremel drill bit to finish off the rest of it. At least that part is going smoothly.
Any suggestions regarding the paint? I m planning on sanding it down and going for another coat on sat. Just painted tonight. I am using Rustoluem Satin Black.
3 Improve build quality. New psu, install fans correctly, replace dust covers,manage cables.
New psu installed in temp case, an Antec Basiq Plus 550. Replacement front and rear dust covers have been purchased. All the remains is putting it all together at the end
4 Restore case to original state and fix components. Remove dynamat, replace missing parts, replace motherboard battery, fix wireless card antenna and reapply A5 thermal geese.
This is on going. A5, batteries, rubber feet and dust cover are all incoming
Finally, I m not sure if anyone is interested. If they (you) are and they're (you're) experienced, I probably need their (your) help (lol..![Crying :cry: :cry:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Specs:
Intel Q9950
Asus P5Q Deluxe
Segate 1tb drive
GTX 460 768
![1004642p.jpg](http://img543.imageshack.us/img543/3490/1004642p.jpg)
![1004640.jpg](http://img233.imageshack.us/img233/965/1004640.jpg)
![1004639e.jpg](http://img225.imageshack.us/img225/2702/1004639e.jpg)
Its a mess.
![1004651.jpg](http://img254.imageshack.us/img254/9356/1004651.jpg)
![1004643g.jpg](http://img221.imageshack.us/img221/4733/1004643g.jpg)
![1004663w.jpg](http://img338.imageshack.us/img338/8505/1004663w.jpg)
![1004662c.jpg](http://img24.imageshack.us/img24/5073/1004662c.jpg)
![1004660y.jpg](http://img684.imageshack.us/img684/1328/1004660y.jpg)
