Resolution (Native or not,custom)
Cri
Hi there!
Are the following resolutions correct?
Tipical 4:3
640x480,800x600,1024x768,1152x864,1280x960,1600x1200
Tipical 5:4
600x480,720x576,1280x1024,1600x1280
Tipical 16:10
768x480,1280x800,1680x1050,1920x1200
Actually in games such as Call of duty, farcry.. I´m not able to select 1280x800, but I get no problem at 1280x768, Isn´t 1280x800 the correct ratio for 16:10 aspect??
We all know the best way to look to our screens is using the native resolutions.
If we haven´t got any high end graphic-card probably we won´t use the native one
Which one should be the best choice for a 16:10 Display??
In a 1600x1200 native screen If we use 800x600 each pixel will be represented with four, that will be quite usefull to get to work games, with a good interpolated resolution, Does this kind of "Trick" also work for any 16:10 aspect resolution??
Thanks in advance
PS: I own a 2005FPW
