Reservoir question
Delemon
I'm looking at getting a res to mount internally for my first WC build, but I don't particularly care for the look of the bay mounted res. I'm looking at the Bitspower Water Tank Z-Multi 250 - POM/Acetal and as a n00b, I want to make sure I get questions out there before I buy all my stuff and then have no clue how to make it all fit.
I'd like to mount it with the single barb located at the top, and the inlet and outlet in the bottom, with one of the bottom ports used for a Bitspower G 1/4in. Temperature Sensor Stop Fitting to directly measure the res coolant (distilled H2O+ silver) temp. The top barb would be used for a fill port of some sort.
So, fillport at top with inlet, outlet, and temp sensor populating the bottom ports. Sound about right?
That's a great res and I love the looks. You may also want to look at the Swiftech micro res rev2. It has several ports for all kinds of configurations and can be mounted just about anywhere. It also bleeds very quickly. The one in my system gets the air out in about 10 minutes because of the angled piece inside.
Wait from what i'm understanding your only going to have an outlet? Correct me if I am mistaken.
Fillport at top, with inlet, outlet, and temp sensor on bottom. The pic of that res from sidewinder shows 1x connector on one end (top), and 3x connectors on the other (bottom).
