Request for info on specific 680i problem
Hello,
The system ( nothing is overclocked unless stated otherwise ):
e6850 ( dual core @ 3 ghz, 1333 fsb ), D-Tek Fuzion waterblock
Abit IN9-32X MAX ( 680i SLI ), active cooling fan installed on northbridge
2gb Corsair Dominator 8500 5-5-5-18(?) Ram ( 2 sticks ), rated at 1066 and running at 1066 with SPD timings
One Raptor 150gb and one NEC DVD-RW ( PATA )
2x XFX 8800 GTS 640mb OC, running in SLI, both with EK fullcover waterblocks.
Enermax PSU ( can't remember the rating off the top of my head ~800? )
CPU temps under load ~25C, Video cards run at 37C and 39C under load. Memtested stable for 24 hours, etc. etc. The system has been up since August of last year.
The Problem
The computer will stall at random intervals at any point during it's operation except while POSTing. This stall lasts for approximately 30 seconds after which the computer recovers. During this time, processes that do not make read/write requests to the hard disk and are already loaded into memory ( such as notepad or firefox ) continue to function properly, whereas other processes such as Eve-Online, Bioshock, or even the Windows OS will become unresponsive until the glitch is over.
I first noticed this problem about 2 months ago, but I haven't gotten around trying to fix it until recently since I have been busy at work.
Now I've got some free time I find that this is really disrupting my game, man! ;)
I have both WinXP and Vista installed and the problem occurs with both OSes so I think that this is likely a hardware issue. Also, because this problem seems to affect only processes that are accessing the hard drive I believe it is located somewhere along the NB->SB->HDD chain.
I'm not at a loss for troubleshooting this problem. To this end I'm going to frag (format) my HDD and reinstall my OS, then test my HDD in another computer,then test my HDD with a pci SATA controller. Unfortunately I have no spare mobo to troubleshoot the NB with but, I'll cross that bridge when I get to it.
The question
I'm not in touch with the enthusiast world as I was back in the days of the Vodoo3 and the Geforce 2, and I was hoping that you might be able to shed some light on this problem. Have you experienced this kind of glitch or have heard of someone who has?
ugh...
I'm glad to see you have added cooling to your northbridge, that'll help.
Given the issue , It's hard to say forsure whats wrong.
I can tell you from personal experience , strikeouts don't like ram above 800MHz or 2 volts.
Mine ran with pc8000 (1000Mhz) for 9 months.Then it had issues.(4 dead sets of ram , bios corruption)
I got lucky that it still works.It's now runnning pc6500 without problems.
You might consider running some 6500/1.85 v ram for ahwhile if yah have some.
