Replacement reserator pump
The pump in my reserator 1v2 went out yesterday, and I'm trying to find a pump that I can use inline because I'm sick of that crappy little pump. I found a nice pump, with the correct size fittings and plenty of gph. The only problem I'm having is that it's 9volt 3amp dc and it didn't come with a power adapter. Any ideas short of buying a proper power supply and wiring them together?
I bought 1 Reserator 1 and 1 Reserator 2 V1 for my upcoming build and am using a generic aquarium pump to move the coolant. I looked for an Eheim, but the aquarium store I was in didn't stock them. The one I picked up is rated at 350GPH, so we'll see how it handles. Are you sure the 9V pump will have enough oomph? If the pump takes a general 9V input, you can probably just pick up a generic 9V transformer from Radio Shack or another electronics outlet.
