replacement psu for x-qpack
Kid8
hello,
im building a new rig and was going to replace the psu in the x-qpack. what are some suggestions for ones that will fit and that have cables that won't be impossible to tidy up. thanks in advance.
any normal atx psu will work and fit fine as long as you use a dvd-cd-rom that is short... like lite-on..
Make sure that it is no more than 5.5 inches deep or it will get really tight, even if you have a short optical drive.
