Replacement Chieftec case sidings.
option141
Aighty,
I have a chieftec case (that looks like the oldschool alienwares, i believe chieftec calls these "dragons" or something) and i'm lookin for a replacement panel (for the side with the clip and window). I want a replacement because i no longer want a window there.
Heres the twist: I dont see replacement side panels on chieftec's site at all. Any ideas on where I could find this?
There really are tons of sites that sell these side panels... I know directron.com sells them as well and you might want to check them out. I know they have the full tower version for the side panels, but I dont know the size of your case (6-5.25 front bays or less). Google turned up a few sites around that sold them as well. I know I replaced mine with a pre window modded one a long time back when they first came out and it was only like 20 bucks...
:) Sold that case ages ago... But I would have had I still had it... Again they arent expensive... And you can usually pick the color to match... What is wrong with having the window???
i'm tired of windows =/
dont ask ... lol. i was thinkin of takin a new panel and making a smaller window maybe - but not that huge one that comes with the chieftec cases usually , you can see too much in my opinion.
