Picked up this Acer AspireRevo AR3610 back in July 2010 (paid $333) and it's been quite the faithful HTPC for us.
Upgraded RAM and has streamed anything locally I've throw at it, but as I'm sure you can imagine HD Flash was crippling.
Recently tried going the Android stick route and picked up a cheap little MK908, had a ton of issues at first but after configuring different ROMs, Kernels and software it's running quite nice. Netflix and Youtube is good, browsing my local LAN kinda sucks with the different SMB file explorers and it's really lacking since we can't use Hulu anymore.
Anyway, I think I want to stick with the full Windows setup and I also just picked up an ASUS T100 Windows 8.1 tablet for $300 that has really rocked my rocks (to replace an older netbook). This thing handles about everything I throw at it.
So what are my options... Would like to keep it small and cheap. I figure if this little Bay Trail Atom can decode anything and everything it shouldn't be too hard to find a good replacement.
Are there any good suggested nettop devices anymore? If not do I need to build a Micro ATX machine? No problem with the actual building, would just need suggestions on parts for a great price/performance ratio.
Thanks!
Sean
Thanks!
Sean
