Removing Bloatware from a Netbook
Just got the same one for my mom.
No resource/guide needed. Just install Revo Uninstaller and go to town. Use common sense and remove anything you don't want.
Then use CCleaner to clean up the startup items to only the necessities.
Then install MSE for AV and you're golden.
Simple.
Then again, the first step takes quite awhile.
