Stormlifter
- Oct 19, 2002
Is there a freeware tweak program or registry edit to remove the start menu from the taskbar? I want it to be permanent, not have to reapply it every reboot.
If you just want to disable the windows key(s) on your keyboard: http://johnhaller.com/jh/useful_stuff/disable_windows_key/
Well I've already removed the start menu button, LClock can do that. Now all I need to do is to stop it from responding to the windows key and basically be unaccessible, pretty much making it as if it didn't exist.
I'm not sure if you want to remove it because it interferes with the Windows key, or if you just hate seeing it. Are you on Autohide?
Use Transbar and set it to 0% opacity (or 100% transparency, whichever it uses).
So the taskbar will technically still be there, but you won't ever see it.
Actually, his suggestion is a valid one. The only conceivable reason to disable and cripple Windows that much is for a kiosk, like Gatticus suggested. I know to some it might make them feel warm and fuzzy inside to do all these crazy tweaks, but there's really no reason to cripple a product you plan on using.Wait so just cause I don't want a start menu means I should move to another OS
What purpose does removing the Start Menu serve?Removing the Start Menu is hardly crippling the OS, what purpose does it serve?
Just don't use it???I find no use for the start menu at all
