Reformatting with Dynamic Drive?
jas0nt
good news: my partitions in Windows are all set to dynamic drive. however, yesterday, i was setting my RAM speeds to 333mhz, and totally fux0red my machine (it wouldn't past post, i was really worried), so i had to reflash my BIOS, remove the jumper, etc. anyway, the BIOS appears to be fixed now.
bad news: however, now, i can't even boot up into Windows without seeing an ugly blue screen. sometimes it says IRQL_NOT_EQUAL, others it has different messages when i remove 2 RAM sticks. anyway, so i was thinking i had to reformat anyway, with all the errors i get, slow bootup times, driver traces, corrputed event logs, etc.
very bad news: however, my main partition with my MP3s and DVDs are set in dynamic drive. when i reformat, everything else will be reformatted in a basic drive, which will mean my general drive would be unreadable (i've done it before, when i reformat all drives and leave behind dynamic ones, it would be unreadable in diskmgmt).
so basically, i want to know if there is anyway i can reset my dynamic drive to basic drive without getting into Windows?
You could try sticking it in another computer, but I question why you would need to reformat to reinstalled windows. reinstall != reformat. A repair would probably work better anyway. But barring either of those, AFAIK no 3rd party programs can touch dynamic drives, not even Partition Magic 8 pro.
You can reformat that partition without destroying data on all the others. The XP setup detects dynamic partitions and will install/format them as needed. As far as I know, the only way to convert back to basic is to reformat the drive and setup partitions again.
