Howdy all...I'm going to be doing a new custom setup on a Lian Li V1000: This one (in black) ....I have lots of options with this case..one is to go a dual with that and the rez cut into the top, but I was also thinking of using 2 single radiators in place of the stock 120 fan locations to avoid cutting this beautiful case. My question to y'all is: is there any advantage to the 2 singles, or would there be any problems. If you look at the pic, I'll be removing the HDD cages and remounting the drives standing up lengthwise to gain some room (note: the pic shows only one hdd cage and mine has two with shorter PSU area)..possibly for a tank-o-matic. Now logic would tell me that the front radiator would be first in the loop and drawing outside air, going to wherever, then to the second which would push out heat. Does this idea make any sense from a practical standpoint?
